Originalmente inviato da Sapphire ad ogni modo ci sarebbe anche il discorso della coda da contare e in piu dubito che vendano il telecomando separato dal modello, o sbaglio |
Sbagli
![^_^](/forum/images/smilies/happy.gif)
C'è la procedura di "binding" per associare la ricevente (quindi il modello) alla Tx.
Q 2: How do I bind the heli to the transmitter? My manual is in Chinese...
A: In this case the manual of the Proto Max offers support. This is the correct procedure:
Turn on the transmitter. Lower the throttle control stick all the way down. Adjust the throttle trim tab until the throttle trim indicator is centered and the throttle position indicator reads 000. Turn off the transmitter.
Connect the LiPo battery to the helicopter. Turn on the transmitter while pressing inward on the throttle control stick until the blinking blue light in the helicopter remains steady, indicating that the receiver is reading signals from the transmitterthis should happen within a few seconds.
If it doesnt work the first time, disconnect the LiPo battery from the helicopter and turn off the transmitter. Repeat the binding procedure again by reconnecting the LiPo battery and turning on the transmitter with the throttle stick depressed. The receiver is now bound to the transmitter and the helicopter is ready to fly.
(fonte:
RcGroups)
Willy.
