Vecchio 08 aprile 13, 12:32   #25 (permalink)  Top
greywall
L'avatar di greywall
Data registr.: 20-01-2013
Residenza: Foggia
Nuovo Firmware 3.0.0 Deviation
E' stata da poco rilasciata la nuova versione del firmware Deviation, che introduce molte novità.
Release Note
Version 3.0.0 del 4 Aprile 2013
Last Updated on Sunday, 07 April 2013 18:37 Written by version-3-0-0 Hits: 787
This is a major release of the Deviation firmware
IMPORTANT: You must install the filesystem along with the new firmware. Make sure to save your models first!
Major Features:
◾Devo7e support
◾Devo12 support
◾Note that the Devo12 support uses the Devo8 GUI and does not take full advantage of the larger screen yet
◾New 'standard' GUI for helicopters
Minor features:
◾Telemetry support for DSM2/DSMX
◾New protocols
◾DSMX
◾Skyartec (needs CC2500 module)
◾WLToys protocol extensions
◾Repetitive low-battery alarm
◾Multiple hardware modules are supported
◾Support for hardware modules with or without power amplifier
◾PPM has more configuration options
◾Support for multiple icons per switch
◾Also support switch icons for Devo10
◾New 'permanent' timers
◾Add error-catching code to make it possible to debug reboots/hangs
Incompatibility:
◾Switches are now numbered (e.g.GEAR0, GEAR1). Deviation will properly convert old models, but older versions of Deviation will not properly support models made for version 3.0 or newer
◾The channel scale is applied after the safety value. If safety is in use, make sure to check the values
DOWNLOAD
Syma S107G, Merlin Tracer80, E-Flite Blade MCX2, E-Flite Blade mSR, E-Flite Blade Nano CP X, E-Flite Blade MCP X BL
greywall non è collegato   Rispondi citando
