Originalmente inviato da Herman70
Ho trovato sul forum vstabi una procedura per la calibrazione del trottle governor sul vbar,
xviii. Calibrate VBar Governor
1. Calibrate Motor Stop
a. TurnonCollectiveControl
b. Raise Motor On Slider until motor turns on – Note
Value
c. Now put that value -12 in Motor Off
d. Now Turn off Collective Control
e. TurnonThrottleHold
f. Raise Throttle to Mid Stick
g. TurnoffThrottlehold
h. If there is a 2 second delay the Motor Stop Value is
too low (-107 as an example).
i. Start increasing Motor Stop by -1 until there is no
delay when switching out of throttle hold.(I ended up with -94)
2. Calibrate Motor Full
b. Go to full throttle on TX(Spool Up)
c. Increase Motor Full until light goes off on YGE indicating Full Throttle(VERY Important). I ended up with 108.
Domani provo..... |
Salve ragazzi,
Problema risolto, ho seguito questa procedura e tutto funge alla perfezione,
Rispetto al gov store Dell YGE e tutta un altra storia, impressionante.
