Originalmente inviato da eux22 devo fare un po' di pulizie, qualcuno sa indicarmi o dove trovare una tabella, dove indicano in base al connettore da scelto quale amperaggio porta.
Mi serviva sapere essenzialmente
i Gold Bullet da 3.5mm
i Gold Bullet da 4.5mm
Xtr60 (ho letto massimo 60A, è giusto)
grazie |
HXT 4mm Gold Connector w/ Protector (10pcs/set)
Rated 90A
Nylon T-Connectors 10 Pairs (20pc)
C.V.D.
ALERT!
These connectors are made from Nylon, making them very tough and difficult to melt, even with the worst of soldering skills.
These are for those customers still stuck with the old t-connector.
Se li avete, buttateli
XT60
Nylon XT60 Connectors Male/Female (5 pairs) GENUINE
Excellent W.S. Deans T-connector replacements.
Made from high-temp Nylon and gold plated spring connectors, both included in the injection mould at the time when forming the connector. The XT60 ensures a solid high-amp connection, perfect for applications up to and beyond 65A constant.
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC)
3.5mm Gold connectors.
Rated to around 80A
ecc..ecc..
Lavativi
