queste sono le specifiche del motore e del regolatore presi da rctimer su ebay e raccomanda una 8040
Model No.: 2826-6
Rpm/V: 2200KV
Weight: 50g
Motor Dimensions: Ф27.7*26.3mm
Shaft Size: Ф3.17*37mm
Battery Opernating: 2-3 Lipo
Idle current: 1.8A
Load current: 18.5A
Power (Watt): 240
ESC(A): 30A
Ri(M Ω): 0.03
Prop/recom: 8040
ltems : 30A
Weight : 28g
Dimensions : 45.0*24.0*9.0mm
Current(A) : 30-40
BEC : 3A
PWM: N/A
Li-Po : 2-3
Ni-Mh/Ni-cd : 4-10Ni-Mh
Features:
BEC: 3A
Constant current 30A Max 40A <10s
Li-Poly 2-3 cells; Ni-MH 4-10 cells Auto Detect
Break On/Off;
Auto Low battery Slow down at 3.0V/cell Lipo, cut-off at 2.9V/cell Lipo
