TowerPro MG995
Ciao,
ho trovato questo Servo STD a 15 euro spedito, e le caratteristiche sembrano ottime.
Che ne dite? Specification : Control System: +Pulse Width Control 1500usec Neutral Required Pulse: 3-5 Volt Peak to Peak Square Wave Operating Voltage: 4.8-7.2 Volts Operating Temperature Range: -20 to +60 Degree C Operating Speed (4.8V): 0.20sec/60 degrees Operating Speed (6.0V): 0.19sec/60 degrees Stall Torque (4.8V): 9kg.cm Stall Torque (6.0V): 11kg.cm Operating Angle: 45 Deg. one side pulse traveling 400usec 360 Modifiable: Yes Direction: Clockwise/Pulse Traveling 1500 to 1900usec Current Drain (4.8V): 8.8mA/idle and 350mA no load operating Current Drain (6.0V): 9.1mA/idle and 450mA no load operating Dead Band Width: 4 usec Motor Type: 3 Pole Ferrite Potentiometer Drive: Indirect Drive Bearing Type: Dual Ball Bearing Gear Type: All Metal Gears Connector Wire Length: 11.81" (300mm) Dimensions: 1.59" x 0.77"x 1.48" (40.6 x 19.8 x 37.8mm) Weight: 1.94oz. (55.2g)
? Features : Coreless Motor
Metal Gear
Double Boll Bearing
Connector Wire Length 300mm ciao Alex |
