Originalmente inviato da Buddyclub start up fallito...
Trouble shooting:
1 Beeps/flashes: Incorrect throttle curve for Gov.-Store
Mode
2 Beeps/flashes: Under-voltage identification
3 Beeps/flashes: Temperature rise warning
5 Beeps/flashes: Receiver signals failed
6 Beeps/flashes: start up failed
Any error that happens during flight is signaled by the ESC
after motor stop (flashing LED and beeps).
In case the ESC reduces power completely because of
low-voltage, critical temperature, receiver signals lost or the
startup failed, the error levels 2,3,5 and 6 will be stored
permanently (crash analysis). To reset these errors
connect the ESC to the battery with the stick at full power
and/or with 100% throttle pre-selection (throttle curve), and
disconnect it after the interval beep. Please leave the stick
at full power, while disconnecting, otherwise you activate
the RC-Setup.
Alternativly the errors can be cleared by connecting the
ProgCard.
With an activated brake, the error is only signaled after a
tension reset or in wind milling position. |
PERFETTO SPARITO!!!
GRAZIE MILLE!!!!
io ho i servi savox, le manine dove si fissano i ball screw hanno 4 fori. io li ho messi al secondo foro, però ho notato che muovendo al massimo elevatore ad alettone qualcuno tocca leggermente nel telaio. Come potrei risolvere. Nel beastx ho provato a diminuire le escursioni ma mi da il led rosso, cioè che è poco, mentre se dò le escursioni giuste il led diventa blu ma mi toccano poi un pò sul telaio.
