Originalmente inviato da chrigui dal manuale
"Antenna fades represent the loss of a bit of information on that specific antenna. Typically its normal to have as many as 50 100 antenna fades on any one of the antennas during a flight. If any single antenna experiences over 500 fades in a single flight, the antenna should be repositioned in the aircraft to optimize the RF link.
Frame Loss represents simultaneous antenna fades on all attached receivers. If the RF link is performing optimally, frame losses per flight should be less than 20.
Hold a hold occurs when 45 contiguous (one right after the other) frame losses occur. This takes about one second. If a hold occurs during flight, its important to re-evaluate the system, moving the antennas to different locations and/or checking to be sure the transmitter and receivers are working correctly. " |
Intanto ti ringrazio per la pazienza!!!
Ma da che manuale lo hai preso? Ieri sera ho scartabellato solo manuali...
