Vecchio 28 febbraio 13, 21:52   #724 (permalink)  Top
MGuerani
L'avatar di MGuerani
Data registr.: 03-01-2013
Residenza: Milano - Solaro
Immagini: 1
Da quello che ho letto, il problema è che l'ESC non riconosce le 5S (le "vede" come 6S) e farebbe il cutoff ad un livello troppo basso... però abbiate pazienza, sono a casa con la febbre e non capisco un cavolo...
edit
questo è quello che ho trovato:
When you plug in a 4s battery, the ESC beeps 4 times, indicating it recognizes that your battery is a 4s. Cool. When you plug in a 5s battery, the ESC beeps 6 times, indicating that it thinks it's a 6s battery. This is cool if you want to run the battery for 5 seconds and almost immediately run into the regular Low Voltage Cutoff of 3.4v/cell. Since the ESC thinks it's 6s, the cumulative voltage is always going to be recognized as low. How do we get around this? Easy.
Set the Low Voltage Cutoff (Item 3: Cut-Off Threshold) to 2.8v/cell when you have a 5s battery installed.
It is VERY IMPORTANT that you switch back to 3.4v/cell when you put a 4s back in there, but for 5s, using a lower cutoff fakes the ESC into letting you run the voltage in the 5s down to a safe and proper discharge value before cutting you off.
Axial SCX10 Dingo - Lancia Delta Tamiya TA01 - Tamiya CC01 - 1/36 Losi Micro-DT
MGuerani non è collegato   Rispondi citando
