12 novembre 06, 23:56
#44 (permalink)
Top |
Data registr.: 20-01-2005 Residenza: Bologna
Originalmente inviato da clayrega Boh, l'ho cercato sul sito della Precision e su RC Groups ma non ho trovato niente! |
Hi guys,
Many of you know that something is cooking at PA. We start getting so many emails asking about our new project, so we decided to share with you some basic information, even before its formal release.
The Katana MD is one of our biggest projects to-date. No, this is not an enlarged version of our Katana Mini, it is truly a new design, which could be easily mistaken (if looking at some of the photos) to be a 35% aircraft.
As you may noticed this model took long to develop and for a good reason. To start with, we have worked out complete new construction techniques and invested hundreds of hours in the development and implementation of several patents in this intricate design. We then continued, tweaking and stretching the aerodynamic design and engineering of the model. The combination of the design itself and the innovative construction technology grants an outstanding model, which simply outdo other planes in the same category.
The Katana MD (MD by the way, stands for "Medium" size..) wing span is 46 inch, but wing span plays a small role in this design - this model is big! It features a huge wing area of 500 sq.in that push the wing loading down to 9.5oz/sq.ft!
There is so much to tell about the Katana MD, but the big difference really is that we designed this plane for advanced and professional pilots, not beginners. In the hands of a pro pilot this plane will perform miracles. If you feel you graduate the Katana Mini, this is the plane for you. I will not lie to you (to try and sell more) and tell you that the Katana MD is an excellent plane for every pilot. It is designed for advanced pilots. If you want to practice your IMAC sequence this plane is for you, its flight characteristics are very similar to a giant scale. And if you want to practice your 3D manouveres - simply slide the battery aft to the recommended CG and youve got it.
Solid elevators that will knock you down (put it this way, push full down elevator in inverted flight and you can take a nap). Stunning Knife Edges with close to zero coupling (I had only one click of rolling coupling with zero elevator, no mixing). Due to its lightweight, the wing area and the designing factors this plane is a serious floater. Harriers with a few clicks of throttle are handless. I flew it today with our 2200mAh 12c pack for 20 minutes!
The current prototype Im flying weigh 940g (33.15oz) and we are still testing and finalizing our new motor PA Thrust 30. More details about this motor and set up later on as it is not finalized yet.
Needless to say that the plane features LOOOONG list of carbon fiber parts in the hardware and mostly in the construction (youll be amazed when you see her guts). And to complete the look we produced a beautiful carbon fiber spinner with a CNC machined back plate to fit perfectly the KMD cowling. you should see that!!!
The Katana MD is almost completely done for you in the factory and most modellers will set it up in one evening. It will be available in a few color schemes of course.
At this point, we cannot expose too many details. We still need to finalize some of the hardware and a few more details. We are doing every thing possible to safely speed up the release date and get into production, but we are not willing to compromise. At this stage we do not have a final release date or a price tag.
Will keep you posted with more details soon.
Shaun
Precision Aerobatics Team |
