Allora nessun esperto sa rispondermi
Nessuno conosce queste OlevinPower
Nelle descrizione cita
OlevinPower 2300mAh, 3.3v Lithium Ion Single Cell. Ideal for custom battery packs or other applications where high discharge rates are required. OlevinPower provide genuine Enerland Lithium Ion~A123 Cells.
Spec:
Nominal Voltage: 3.3v
Nominal Capacity: 2.3A
Standard Charge: 3.6A
Max Charge: 10C
Max Allowable Charge Voltage: 4.2v
Max Discharge: 30C (Continuous)
Burst Discharge: 60C
Weight: 70g
Dimensions: 66.5mm x 26mm
Note: This is a genuine A123 cell.
Sembrano le caratteristiche della Life ma poi le chiama Litio ????
