Originalmente inviato da ivan-edffer |
Ehm, per non aprire un altra discussione (viste le migliaia già simili
![:unsure:](/forum/images/smilies/unsure.gif)
) se a qualcuno sconfinfera l'inglese potrebbe vedersi questi link di forum che ne descrivono già molte di ventole:
WM 400
Fan testing Information (motor/fan combo's)
JetScreamer 1400 Bench Test - RC Groups RCGroups.com: The ABCs of Radio Control - Aircraft, Boats, and Cars! 90 mm Electric Ducted Fans (Wemotech Midifan, HET 9305, Schuebeler DS-51)
Midifan
Testing 90mm Midi fan @ nearly 10 Lbs thrust - RC Groups Welcome to Jet Hangar Hobbies, Inc. 3 ARC motors tested in 90mm fan - RC Groups "neu" motor - RC Groups HET 9305
HET Typhoon 600-42 and 600-43 test data - RC Groups 3 ARC motors tested in 90mm fan - RC Groups HET 9305 discussion... - Page 2 - RC Groups 100 mm Electric Ducted Fans (Tam Jets TJ 100, Himark 96, Haoye 4 inch)
TJ 100
Stumax/DS75/Dynamax/TJ100 and others benched - RC Groups Update infor TJ100 with Thunder Power Pro-cells - RC Groups Himark/Himaxx 96 mm fan
Himax 96mm fan /motor combo - RC Groups
Where to buy
100mm Plastic Electric Ducted Fan Units 1 Set 3.94"/ 100 x 79mm Haoye 4 inch fan
Another Haoye 4-inch Fan Tested - RC Groups 110 mm Electric Ducted Fans (Stumax, DS-75, Haoye 4.5 in.)
Stumax
Stumax/DS75/Dynamax/TJ100 and others benched - RC Groups The Stumax EDF system is here at last! - RC Groups DS-75
Stumax/DS75/Dynamax/TJ100 and others benched - RC Groups Haoye 4.5 inch
Hoaye 5" fan test - Page 6 - RC Groups 120 mm Electric Ducted Fans (Turbax, EVF, Dynamax, Haoye 5 inch, Airpower 120, Schuebeler DS-94, Turbofan 4000)
Turbax
Welcome to Jet Hangar Hobbies, Inc. The E-Turbax Diet plan - Page 2 - RC Groups 120mm setups that work - RC Groups BVM EVF http://www.bvmjets.com/Pages/EVF5212.html http://www.bvmjets.com/Pages/EVF4010.htm
Dynamax
XPS Fan Adapters and systems - RC Groups Dyn-E-Max Ducted Fan - RC Groups Stumax/DS75/Dynamax/TJ100 and others benched - RC Groups Haoye 5 in. fan Hoaye 5" fan test - RC Groups Air Power AP 120
AP1200 / mega 120 EDF Bench Test /video - RC Groups Airpower 120mm Fan - RC Groups DS-94
DS_94 & Nue motor - RC Groups 120mm setups that work - RC Groups Turbofan 4000
TF4000 Mega 120 Vs Neu 1912 1Y / Video - RC Groups 120mm setups that work - RC Groups 120 mm Electric Ducted Fans (Tubofan 8000, Byron 6 in.)
Turbofan 8000
Turbofan 8000 - RC Groups Byron 6 ich fan
Byron glow fan conversion - RC Groups Mercury EDF in alluminio da 64mm a 120mm
Link al sito della casa madre taiwanese (EPF Hobby)
EPF HOBBY - Powered by ECShop
Mentre per i più ferrati in matematica ed aerodinamica c'è questa bella
tesi del 2008 da scaricare... finchè possibile farlo:
drum.lib.umd.edu/bitstream/1903/8752/1/umi-umd-5771.pdf
