Originalmente inviato da mastermide ciao tutti c'è qualcuno che mi po dare una mano per settare castle ice 100 con il motore gaui601.grazie |
Stator Diameter 40 mm(1.56 in)
Stator Thickness 20 mm(0.975in)
No. of Stator Arms 12
Magnet Poles 8
Motor Wind 10 Turn Delta
Motor Wire 24-Strand 0.25mm
Motor Kv 910KV RPM/Volt
No-Load Current (Io) 1.95 Amps
Motor Resistance (Rm) 0.015 Ohms
Max Continuous Current 65 Amps
Max Continuous Power 1820 Watts
Weight 284 Grams (9.21 oz)
Outside Diameter 48.9 mm (1.9 in)
Shaft Diameter 4.98 mm (0.19 in)
Body Length 46.5mm (1.81 in)
Overall Shaft Length 78.7 mm (3.10 in)
Max Lipo Cell 8s
Motor Timing 5deg
Drive Frequency 8kHz
