io sullo stretch 'dopato' ho messo yep 80A ma solo perche' ho messo su il 3226 scorpion
credo che con il 3026 il 60A non abbia problemi visto che nelle specifiche il max assorbimento e' a 52A
Scorpion HK-3026-880 Specifications
Stator Diameter ............................ 30.0 mm (1.181 in)
Stator Thickness ........................... 26.0 mm (1.024 in)
No. of Stator Arms ................................................ 12
No. of Magnet Poles ............................................... 10
Motor Wind ............................................ 10 Turn Delta
Motor Wire ..................... 14-Strand 0.25mm (30 AWG)
Motor Kv ............................................. 880 RPM / Volt
No-Load Current (Io) ................... 2.30Amps @ 6 volts
Motor Resistance (Rm) ............................. 0.026 Ohms Max Continuous Current ............................... 52 Amps
Max Continuous Power .............................. 1450 Watts
Weight ......................................... 199 Grams (7.02oz)
Outside Diameter .......................... 37.5 mm (1.476 in)
Shaft Diameter ............................. 5.00 mm (0.197 in)
Body Length ................................. 48.4 mm (1.906 in)
Overall Shaft Length ...................... 74.2 mm (2.921 in)
2x Prôtos Carbon Stretch FBL:MKS9660 / MKS9670 + BEASTX detti "i gemelli" Acrobat Shark FBL +BEASTX detto "Emmenthal / Mucca" |
