Ho appena ricevuto risposta da parte della Century:
Hello,
The fuselage is compatible with the TREX600. The only thing that is required
to do would be to make sure to not use the battery tray for the TREX600. You
would need to mount the batteries on the side.
This particular fuselage is currently out of stock.
purtroppo dovrò cercare un'altra fusoliera per il mio 600EFL PRO!
Voi avete qualche suggerimento in merito?
