questa è parte della descizione della tua rx....
"The PowerSafe main unit is not a receiver. The PowerSafes main unit is a power distribution center that provides up to 35-amps continuous and 50-amps peak current to power your system. Through extensive testing our engineers discovered that mounting the receiver in the typical location in sophisticated aircraft (an aircraft with many high-current draw servos and/or conductive materials), at the end of the servo and battery leads, is not the optimum location to provide the clearest RF signal. The AR12120 PowerSafe uses up to four (a minimum of three are required) remotely mounted receivers that can be optimally placed in your aircraft providing the best possible RF link in the most demanding conditions."
Tolto che vuole 3 satalliti x funzionare a dovere (ma xè vendono ancora Spektrum???) non ho trovato, anche nel resto della descrizione, nulla che specifica "Soppressione interferenze o amplificazione segnali; Quindi è una RX....e l'idea di una rx che "può" erogare picchi di 50A...mi fa
