Discussione
BuddyPrice su HobbyKing, posta qui i tuoi ;-)
26 dicembre 12, 11:16
935
permalink
Top
MattiaModellismo
Data registr.: 14-01-2012
LIPO 2s 5000 mah 30-40 c
ZIPPY Flightmax 5000mAh 2S1P 30C hardcase pack (ROAR APPROVED)
riceventi HITEC COMPATIBILI
2.4Ghz A-FHSS Compatible 8CH Receiver (Hitec Minima compatible)
prolunga cavo bilanciamento
JST-XH 3S Wire Extension 20cm (10pcs/bag)
Spiral wrap tube ID 3mm / OD 4mm (Clear - 2 Metre)
NASTRO PRISMATICO PER BILANCIARE LE PALE
Ultra-thin Prismatic Sticker Sheet (1mtr)
LIPO 1S 300 MAH 45C NANOTECH (PER FBL 100 OPPURE MCPX)
Turnigy nano-tech 300mah 1S 45C Lipo Pack (Suits FBL100 and Blade mCPx)
RICEVENTE HITEC COMPATIBILE (MICRO)
2.4Ghz A-FHSS Compatible 5CH Micro Receiver (Hitec Minima compatible)
AEREO
Skylark L-9 Rubber Powered Freeflight Model 2 in 1 Monoplane or Bi-plane
XT60 Harness for 2 Packs in Series (1pc)
XT60 Harness for 2 Packs in Parallel (1pc)
T-Connector to XT60 Battery Adapter Lead (2pc)
XT60 to T-Connector Battery Adapter Lead (2pc)
CONNETTORI
Male XT60 <-> Female T-Connector (1pc/bag)
LIPO-SACK
Lipoly Charge Bag 14 x 23 cm
HXT 4mm Connector to T-plug conversion charge lead
XT-60 to HXT 4mm Battery Adapter Lead (2pc)
Hi Sky FBL 100 - T-Rex 450 Sport V2 - Arrow plus Flybarless - Easystar II - Graupner Mini Taxi - Ansmann Mad Rat - TT MTA4
Aurora 9 - Funcub - STINGER 64 EDF 4S
MattiaModellismo
Visualizza profilo pubblico
Trova altri messaggi di MattiaModellismo
