Vecchio 10 dicembre 12, 21:59   #4 (permalink)  Top
TermicOne
L'avatar di TermicOne
Data registr.: 02-01-2004
Residenza: Vicino a Saronno
SW setup
1 - scaricato Arduino ultima versione:
Arduino - Software
2 - scaricato MegaPirate NG ultima versione:
MegaPirateNG_2.7_R4.zip - megapirateng - MegaPirateNG 2.7 R4 - MegaPirate Next Generation - Google Project Hosting
3 - copiato il contenuto delle cartelle "libraries" e "tools" di MegaPirateNG nelle analoghe cartelle di Arduino
4 - configurato il file APM_Config.h per la CRIUS AIO Pro
Codice:
// Select your sensor board
#define PIRATES_SENSOR_BOARD PIRATES_CRIUS_AIO_PRO_V1
	PIRATES_ALLINONE
	PIRATES_FFIMU
	PIRATES_FREEIMU
	PIRATES_BLACKVORTEX
	PIRATES_FREEIMU_4 					// New FreeIMU 0.4.1 with MPU6000, MS5611 and 5883L
	PIRATES_DROTEK_10DOF_MPU 		// MPU6000, MS5611 and 5883L
	PIRATES_CRIUS_AIO_PRO_V1    // Crius AllInOne Pro v1
// RC configuration
// Uncomment if you uses PPM Sum signal from receiver
//#define SERIAL_PPM ENABLED
#define TX_CHANNEL_SET	TX_mwi
	TX_set1							//Graupner/Spektrum												PITCH,YAW,THROTTLE,ROLL,AUX1,AUX2,CAMPITCH,CAMROLL
	TX_standard					//standard  PPM layout Robbe/Hitec/Sanwa	ROLL,PITCH,THROTTLE,YAW,MODE,AUX2,CAMPITCH,CAMROLL
	TX_set2							//some Hitec/Sanwa/others									PITCH,ROLL,THROTTLE,YAW,AUX1,AUX2,CAMPITCH,CAMROLL
	TX_mwi							//MultiWii layout													ROLL,THROTTLE,PITCH,YAW,AUX1,AUX2,CAMPITCH,CAMROLL
// Select your baro sensor
#define CONFIG_BARO AP_BARO_MS5611_I2C
	AP_BARO_BMP085_PIRATES
	AP_BARO_MS5611_I2C
// Warning: COPTER_LEDS is not compatible with LED_SEQUENCER, so enable only one option
#define COPTER_LEDS ENABLED     // New feature coming from ArduCopter
//#define LED_SEQUENCER ENABLED   // Old Oleg's LED Sequencer, see leds.pde for more info
#define MAX_SONAR_RANGE 400
#define OSD_PROTOCOL OSD_PROTOCOL_NONE
	OSD_PROTOCOL_NONE
	OSD_PROTOCOL_SYBERIAN
	OSD_PROTOCOL_REMZIBI  // Read more at: http://www.rcgroups.com/forums/showthread.php?t=921467
// For BlackVortex, just set PIRATES_SENSOR_BOARD as PIRATES_BLACKVORTEX, GPS will be selected automatically
#define GPS_PROTOCOL GPS_PROTOCOL_AUTO
	GPS_PROTOCOL_NONE 	without GPS
	GPS_PROTOCOL_NMEA
	GPS_PROTOCOL_SIRF
	GPS_PROTOCOL_UBLOX     <<< Select this for UBLOX LEA-6 (CRIUS GPS boards and others)
	GPS_PROTOCOL_MTK16
	GPS_PROTOCOL_BLACKVORTEX
	GPS_PROTOCOL_AUTO	auto select GPS
#define SERIAL0_BAUD			 115200	// Console port
#define SERIAL2_BAUD			 38400	// GPS port
#define SERIAL3_BAUD			 57600	// Telemetry (MAVLINK) port
// New in 2.0.43, but unused in MegairateNG
// MPNG: Piezo uses AN5 pin in ArduCopter, we uses AN5 for CLI switch
#define PIEZO	DISABLED
#define PIEZO_LOW_VOLTAGE	DISABLED
#define PIEZO_ARMING		DISABLED
#define FRAME_CONFIG QUAD_FRAME
	QUAD_FRAME
	TRI_FRAME
	HEXA_FRAME
	Y6_FRAME
	OCTA_FRAME
	OCTA_QUAD_FRAME
	HELI_FRAME
#define FRAME_ORIENTATION X_FRAME
	PLUS_FRAME
	X_FRAME
	V_FRAME
Collegata la scheda al PC con USB e, dopo aver fatto scongiuri vari, ho compilato e caricato il sw.
Per ora TUTTO OK!
Luciano
TermicOne non รจ collegato   Rispondi citando
