Vecchio 18 novembre 12, 13:16   #1671 (permalink)  Top
romoloman
Adv Moderator
L'avatar di romoloman
Data registr.: 15-08-2007
Originalmente inviato da Xiao5 Visualizza messaggio
Ho provato il setting che si diceva, 18,5 ms ppm (+ o - mi pare sia lo stesso) ho regolato i canali in base alla ricevente (testato su una a 4 canali e una a 6) e pare funzioni bene! ;) non ho reinstallato nulla sulla radio. Open9x con l'opzione DSM che ovviamente non uso (come dicevi va lasciata su PPM).
Il trasmettitore settato come di default da fabbrica (no blink posteriore).
Comunque guarda cosa dice Hobbyking sul sito:
"Notice to customers 17-Nov-2010: We are aware of a possible problem on channel 2 when used with some radios. We have confirmed this is a compatibility issue and not a fault with the product. Our engineers are currently working to resolve this issue. We will update this space with more information as it becomes available and we are working tirelessly to ensure a positive outcome for our loyal customers. We appreciate your patience and understanding while this issue is being resolved.
UPDATE 17-11-2012: Incompatibility has been pinpointed to 9X radios only and 9X radios with modified software. We will have more information and a solution before the 24-11-2012 and be offering a replacement/refund solution once we have the exact details of the issue."
Quanto a raccontare balle non li batte nessuno...
Basta vedere i commenti degli utenti relativi alle radio JR....
Do HK actually read / listen? I've just seen the statement made on 17/11/12 saying it only affects 9X radios. NOT TRUE and I was one of the first to state the problem exists on PCM9XII and X388S transmitters made by JR! Why lie about it? It will just make your customers angry. You will gain more respect and loyalty by admitting there's a problem and providing a satisfactory solution for your customers. Please don't treat us like idiots!
"UPDATE 17-11-2012: Incompatibility has been pinpointed to 9X radios only and 9X radios with modified software." Huh??? Can you tell me what a perfetcly standard PPM signal from a 9x can cause this module to fail, while a perfectly standard PPM from another radio wouldn't?? You seem to have missed the reports from JR radio users too. If your module can't take what all the others on the market can, then it IS a defect of your product whether you call it "incompatibility" or anything else. I use 5 different PPM-based modules on my flashed 9x, they all work perfectly well and reliably.
Grazie "TRANQUILLO"
FAI 15766
Ultima modifica di romoloman : 18 novembre 12 alle ore 13:20
romoloman non รจ collegato   Rispondi citando
