11 novembre 12, 17:44
#48 (permalink)
Top |
Data registr.: 09-04-2008 Residenza: Svizzera e dintorni....
Originalmente inviato da Ferrari Non va quella centralina perchè al 99% è stata programmata per elicotteri quindi non ha nessun controllo dell anticipo allo start ,l MCU ha un prescaler per controllo mappa da 800 a 10000 RPM mentre quella da elicottero da 1600 a 20000 RPM .
Quantity to about 1000 pcs , shipping time about , September 2010 ~ April 2011
Because program errors the ignition system of the batch Hand-start the engine will cause
difficulties, They cant be hand started by flipping the prop as usual.Each one, if there is no
problem using the starter or setting the timing at 34 degrees BTDC and they started perfectly.
If the hand is difficult to start the engine, please check to see if there are features
The batch features are as follows
Opened the ignition box bottom of the label, Open the bottom shell, speed RPM signal lines
marked with white casing, It is possible in this batch .
Xu Liang
Chi ti ha dato il motore doveva saperlo . | Infatti sulla mia centralina c'é come data 19.11.2010, allora é una di quelle !!!!! |
