Vecchio 31 ottobre 12, 21:48   #23 (permalink)  Top
romoloman
Adv Moderator
L'avatar di romoloman
Data registr.: 15-08-2007
Originalmente inviato da cecca95 Visualizza messaggio
Di default Arduino imposta i pin 9, 10, 11 e 3 per lavorare a 488Hz, e i pin 6 e 5 a 976Hz.
per regolare la frequenza devi agire sui timer.
Attenzione a cambiare i divisori dei PWM:
Dalla documentazione di Arduino:
* The resulting frequency is equal to the base frequency divided by
* the given divisor:
* - Base frequencies:
* o The base frequency for pins 3, 9, 10, and 11 is 31250 Hz.
* o The base frequency for pins 5 and 6 is 62500 Hz.
* - Divisors:
* o The divisors available on pins 5, 6, 9 and 10 are: 1, 8, 64,
* 256, and 1024.
* o The divisors available on pins 3 and 11 are: 1, 8, 32, 64,
* 128, 256, and 1024.
* PWM frequencies are tied together in pairs of pins. If one in a
* pair is changed, the other is also changed to match:
* - Pins 5 and 6 are paired on timer0
* - Pins 9 and 10 are paired on timer1
* - Pins 3 and 11 are paired on timer2
* Note that this function will have side effects on anything else
* that uses timers:
* - Changes on pins 3, 5, 6, or 11 may cause the delay() and
* millis() functions to stop working. Other timing-related
* functions may also be affected.
* - Changes on pins 9 or 10 will cause the Servo library to function
* incorrectly.
Grazie "TRANQUILLO"
FAI 15766
romoloman non รจ collegato   Rispondi citando
