Originalmente inviato da liftbag Ma Blade, sei sicuro che il canale Gyro (5) influenzi veramente il gyro di coda?
Sarebbe la prima volta nei micro AS3X E-flite |
Lift, ti quoto non per smentirti, ma cercando di raccordare le diverse domande, dubbi e risposte in un continuum che possa essere efficace per chi legge.
Mi ha finalmente risposto HH in dettaglio, e vi posto la mia domanda e la loro risposta
Q:
Hi, 3-axis gyro has 3 different gains to be adjusted, normally.
Your reply (ndr: avevo già posto la questione e la loro criptica risposta fu ":
The gain value is set to 100% and you would change the gain from the programmable transmitter. ") refers to a single gyro gain.Can you please clarify answering to the folllowing:
- which TX command (DX6i) exactly modify the gyro gain?
- which command is actually impacted by this set up? I presume rudder gain, can you confirm?
- how can I change the remaining 2 axis gains (ail and elev)?
thanks
HH answer:
You transmitter has a Gain setting in the menu lable GYRO. You enter into the Gyro menu and you can set the gain values. There is a Zero position which is Normal flight, you can set the value to Gain that is fits. The 1 position is for Stunt Mode, which is more aggressive style of flying, and you adjust the gain to the type of flying you will need. A Gain setting over 50% is a heading lock mode and a Gain setting of under 50% is rate mode. ...
Adesso a ciascuno di noi la sperimentazione ed interpretazione di questo "oracolo"
