Originalmente inviato da santafalk valuto uno dei due motori .. l importante che sia impeccabile .. grazie |
Ciao,
ho un DM111 nuovo in scatola che vendo a 390 euro + 9 di spedizione.
DM-111 Gas Engine 111cc/11.2HP/7500RPM - Similar in size, weight & power to DLA-112, features angled plugs, ideal for tight cowls & genuine Walbro Carb, all engines are factory run.
Engine type:
Boxer Twin cylinder, 2-stroke, air-cooled
Bore x stroke:
45x35 mm
Piston displacement:
111.33cc
Max. power:
11.2HP
Prop Rev:
6600RPM at 28x8 Prop Static Thrust: 34-35 kg
Prop Rev:
6850RPM at 28x10 2-blade wood prop
Compression ratio:
7.8:1
4.8-6.0V Electronic CDI ignition
Spark plug:
CM6 Type
Carburetor:
Walbro Diaphragm/Choke
Start mode:
Anticlockwise Push Prop Start
Dimensions:
255(295) x 190 x 170(230)mm
Weight:
2908g
