Eli, Mad, Bandit:
questo e' il sh263 sul sito savox:
This is the Savox SH-0263MG Super Torque Metal Gear Micro Digital Servo.
Features:
Dual ball bearings in a micro servo? Yes, that is correct 2BB in a micro!!!
Over-spec refined design out performs ordinary micro size servo.
The metal case design looks awesome and allows for cooler and smoother operating temps.
Metal gears form a solid framework for precise control and operation.
Strict production and quality control of plastic components.
Our servos are totally green from materials to production, these servos are environmentally friendly.
Ideal for cyclic servos for 250/450 class heli's, 1/16 scale surface vehicles, 3D aircraft, and park flyer airplanes. Dimensions(mm): 22.8X12.0X25.4
Weight(g): 15.0
Speed(@4.8V sec/60): .13
Torque(@4.8V oz-in): 25.0
Speed(@6.0V sec/60): .10
Torque(@6.0V oz-in): 30.6
Gear: Metal
Bearing: 2BB
Case: Aluminum
21 Tooth Spline
Questo e' il sh264 sempre sul sito savox
This is the Savox SH-0264MG Super Speed Metal Gear Micro Digital Servo.
Features:
Ideal for rudder servo for 250/450 class heli's, 1/16 scale surface vehicles, 3D aircraft, and park flyer airplanes. Dimensions(mm): 22.8X12.0X25.4
Weight(g): 15.0
Speed(@4.8V sec/60): .08
Torque(@4.8V oz-in): 11.1
Speed(@6.0V sec/60): .06
Torque(@6.0V oz-in): 16.7
Gear: Metal
Bearing: 2BB
Case: Aluminum
21 Tooth Spline
come vedte stesse dimensioni ma il 264 e' molto piu' veloce. SU FL costano uguali. Perche' avete preso i 263 e non i 264 ? Io, per quanto vedo, prenderei direttamente i 264...
