Discussione
BuddyPrice su HobbyKing, posta qui i tuoi ;-)
22 settembre 12, 21:40
808
permalink
Top
GunTanK
Data registr.: 11-03-2006
Residenza: Caldogno
Mo ci metto un' ora a postarveli tutti.....
Twist and Turn Electric Retract with 3mm Landing Gear Leg (2pc) 29.0g
1404N 2290Kv 9.2g 3.5A 160g Thrust Outrunner
TURNIGY Plush 6A /.8bec/6g Speed Controller
Folding Propeller 6x3inch
Ar6300 Mini JST Plug and Servo Lead (5pc)
Micro Servo Connector Lead 1.25 Pitch - Female Plug (5pcs/bag)
Micro Servo Connector Lead 1.25 Pitch - Male Plug (5pcs/bag)
Micro Horn Size C (12mm x 6mm - 10pcs)
Micro Horn Size A (10mm x 8mm - 10pcs)
Micro Control Rod Rocker Horn (7mm x 3mm - 10pcs)
Nylon Clevis 3x22mm (10pcs)
Nylon & Pinned Hinge 16x28.5 (10pcs)
Blind Nut M2 size (10pcs)
Rounded Phillips Head M2x12 (10pcs/set)
Self Tapping Screws w/shoulder M2x12 (10pcs/set)
Self-Tapping/Machine Screws W/Shoulder 2x12 (bag of 100pc)
Glass Fiber Cloth 450x1000mm 18g/m2 (Super Thin)
Glass Fiber Cloth 450x1000mm 48g/m2 (Ultra Thin)
Glass Fiber Cloth 500x1000mm (Medium weight)
Control Rod/ABS Sleeve (1pc/bag)
GWS EP Propeller (DD-5030 127x76mm) (6pcs/set)
Corona CS-239HV Analog Slim Wing Servo (Metal Gear) 4.6kg / .13sec / 22g
5A 1S Brushless Controller
Mini Plug Extention for Micro Battery 10cm (5pcs/bag)
2.4Ghz SuperMicro Systems - Brushless ESC - 3.5A
"Fondatore della fede Stronzista"
GunTanK
Visualizza profilo pubblico
Trova altri messaggi di GunTanK
