Vecchio 21 agosto 12, 22:24   #10 (permalink)  Top
discovery2005
L'avatar di discovery2005
Data registr.: 23-01-2009
Residenza: Casa del diavolo
Ho trovato questo.. MKS DS95 Micro Coreless Digital Cyclic Servo - DS95
conoscete questa marca?? io non l'ho mai sentita, ma sembra buona
Và 1520 ed ha queste caratteristiche
The Ultimate servo for your 450 sized helicopter !!
INCLUDES
- MKS DS95 Servo ID#S0013010
- Servo Horn Package, x1
Specifications:
• Dead band: 0.001ms (Default)
• Control System: +Pulse Width Control
• Working frequence: 1520μs / 333hz
• (RX) Required Pulse: 3.0 ~5.0 Volt Peak to Peak Square Wave
• Operating Voltage: 4.8 ~6.0 V DC Volts
• Operating Temperature Range: -10 to + 60 Degree C
• Operating Speed (4.8V): 0.066 sec/60° degrees at no load
• Operating Speed (6.0V): 0.053 sec/60° degrees at no load
• Stall Torque (4.8V): 2.44 kg-cm (33.9oz/in)
• Stall Torque (6.0V): 3.05 kg-cm (42.3oz/in)
• 360° Modifiable: YES
• Motor Type: 12mm Coreless Motor
• Potentiometer Drive: Direct Drive
• Driver Type: FET
• Bearing Type: Dual Ball Bearings
• Gear Type: Chrome Gear
• Case: All Alumimnum Outer Case
• Programmable: No
- Weight: 21.21g (0.75 oz)
- Dimensions: 23X12X27.25 mm (0.9X0.47X1.07 in)
- Connector Wire Length: 20.0cm (7.8 in)
discovery2005 non è collegato   Rispondi citando
