Vecchio 06 ottobre 06, 18:26   #12 (permalink)  Top
Castor
Data registr.: 17-09-2006
Residenza: Viterbo
raptortechnique.com dice questo a riguardo del serraggio pale:
Adjust the tightness of the blade bolt just tight enough so that if you hold the helicopter on the side with the blades stretched out and parallel to the ground then give the helicopter a bump the blades will not move.
Castor non รจ collegato   Rispondi citando
