Originalmente inviato da rambodue scusami vado a sighiozzo ....
costa 0,75 dollari ![](http://a248.e.akamai.net/origin-cdn.volusion.com/fkubh.gvxyv/v/vspfiles/photos/Resonator-1.jpg)
This is the resonator used as the primary clock source for the mCP X MCU. It can crack or fall off in crashes.
Failure of the resonator will result in a mCP X that will not enter bind mode. The non physical symptoms are a single flash when the battery is connected. There may also be other flashes at long intervals from the internal watchdog timer. |
grande
infatti é quello che mi succede fa un flash appena collego la batteria e poi niente.
però non mi hai detto dove lo posso prendere
![:fiu:](/forum/images/smilies/fiu.gif)
