Vecchio 11 luglio 12, 20:27   #863 (permalink)  Top
atomas72
Moderatore
L'avatar di atomas72
Data registr.: 16-04-2007
Originalmente inviato da ffala Visualizza messaggio
Ciao a tutti, mi potete indicare come impostare la radio Dx7s per selezionare i banchi dalla radio.
Dal forum della Mikado:
Enabling Bank Switching on DX7
DX7 using the flight mode switch
1. Go to the “system” menu, scroll to the [INPUT SELECT] submenu and set ‘GEAR’ to GEAR and ‘AUX2’ to INH.
2. Go to the “normal” menu, scroll to the [REVERSING SW] submenu and set 'ch 5' to NORM.
3. Scroll to the [SUB TRIM] submenu and set 'GEAR' value -75.
4. Scroll to the [TRAVEL ADJUST] submenu and set 'GEAR' upper and lower values to +100% and -100%.
5. Scroll to the [PROG. MIX1] submenu and set the following:
GEAR -> GEAR
RATE +75%
0%
SW:F-S12
OFFSET: 0
6. Scroll to the [PROG. MIX3] submenu and set the following:
GEAR -> GEAR
RATE +100%
0%
SW:F-S2
OFFSET: 0
7. Go to the “system” menu, scroll to the [INPUT SELECT] submenu and set ‘GEAR’ to INH and ‘AUX2’ to F.MOD.
You will now be set up with the following:
• Throttle Hold = Bank 1
• Normal flight mode = Bank 1
• Flight Mode 1 = Bank 2
• Flight Mode 2 = Bank 3
Before flying, disconnect your motor and test your heli on the bench with your vbar connected to your laptop and verify that you can see the banks switching. Also, ensure that you have the vbar settings copied across all banks 0 to 3. If this is not done, you could loose control of the heli when switching to a bank that is not programmed.
It's really useful when trying out different vbar settings during a single flight. Try it for yourself.
"C'è una forza motrice più forte del vapore, dell'elettricità e dell'energia atomica: la volontà."
Albert Einstein
atomas72 non è collegato   Rispondi citando
