Vecchio 18 giugno 12, 00:38   #935 (permalink)  Top
romoloman
Adv Moderator
L'avatar di romoloman
Data registr.: 15-08-2007
Originalmente inviato da CarloRoma63 Visualizza messaggio
Mi rispondo da solo:
da FAQ - gruvin9x - Frequently Asked Questions - Turnigy/iMax/Eurgle/FlySky 9X RC Radio Firmware (forked from ER9X Oct. 2010) plus an enhanced Controller Board design - Google Project Hosting
Q. How do I delete a DR/EXPO, MIXER line or model?
A. Click [MENU] once on the line/model you want to delete, so that is becomes 'selected', as if you were going to copy or move it. Then, while it is still selected, press [EXIT LONG].
This same procedure should work for deleting lines in all similar menus. In the models menu, you get an 'Are you sure?' type pop-up, for extra safety.
NOTE: You cannot delete the currently active model. (It's a safety feature.)
Funziona anche con Open9x
grz comunque..
Carlo
Ti avevo risposto,in effetti cambia poco rispetto a gruvin, tieni presente che i menu di gruvin sono stati disegnati da Bertrand (il papà di open9x)
Grazie "TRANQUILLO"
FAI 15766
