che poi spendendo 2500,00 mi dicono che a 1400 giri il rotore ha problemi mi farebbe girare pure le p@@@e..
dal sito banshee:
Note/Disclaimer: As a consequence of our uncompromising design and use of materials resulting in the extreme stiffness and agility of our helicopter there is a main rotor speed range which should be avoided. Between 1300-1400 RPM (this is partially depended upon the rotor blades being used) there occurs a slightly rotor oscillation, resulting in an unsmooth flight. It is our recommendation that you choose rotor speeds above or below this range.
http://snipurl.com/27ih6f
