At these speeds, the oil can get thrown out of the bearings in as little as 10-15 flights. Once the bearings loose their lubrication, they can heat up and wear out very quickly. A small drop placed on each bearing about once every 10-15 flights is enough to maintain proper lubrication to insure the longest possible life for your motor bearings.
devo tradurre?
