Originalmente inviato da ALE1969 |
Sul manuale d'uso del mio 58 IRS dichiarano:
Before using the engine, please read these instructions carefully.
Congratulations on choosing the gas engine MVVS 58. MVVS 58 has been designed and manufactured for propeller-powered radio-controlled model planes. It is able to meet all of your expectations of an acrobatic racing engine. Bore Maximum power output ** Stroke Maximum torque ** Weight of complete engine without ignition* Fuel Weight of ignition unit Lubrication Oil with petrol inmixture 1:40
RpM range * Some manufacturers state the weight of incomplete engines. The value in the table above stands for the weight of a completely assembled engine, including the spark plug, carburetor, drive washer and prop screws. ** Power output varies with the exhaust used. The value given in the table stands for the maximum available power output.
Potenza massima 8,5 HP a 6950 giri (con scarico originale)
Bisognerebbe scrivere alla MVVS per chiedere di confermare questi dati e farsi dire che differenza c'e' tra il PROSPORT ed l'IRS
Questo e' il link del manuale dell' IRS in PDF
http://mvvs.nl/
