Io carico le 3S sia da 1800 sia da 2200 e mi sono costruito i cavi per caricare/bilanciare. Ne faccio 6 a botta.
per info leggete qui
How-To: Parallel Charging - TJinTech
riporto un pezzo...
- All the packs you charge in parallel mustbe the same type and cell count. There is no need to match the capacity, C-rating, age or brand for parallel charging. For example you can charge a 3s 2200mAh 15C lipo, a 3s 3200mAh 25C lipo and a 3s 850mAh 35C lipo together, but you can not charge any 3s lipo in parallel with a 4s lipo.
- Ideally the packs to be charged should all be at a similar voltage. If I had to put a number on it I would say that all cells should be within .2V for each other. This is not required but is a good practice.
anche qui
Parallel LiPo Charging ? The Faster & Safer Way To Charge?
