Originalmente inviato da bandit golosoneeeee ... che fa l'S rispetto alla versione normale? |
Diciamo che è un'evoluzione della versione classica con un bel pò di cosette in più.
Vi riporto la descrizione del produttore:
The TAROT-S Version ZYX high performance multi-function 3-axis gyro system is the lightest flybarless system in the world. It is compatible with all 200-700 nitro or electric power helicopters and support 90, 120, 135, and 140 degree CCPM swashplate systems. Furthermore, it is compatible with all type servos, and support firmware update. The setup process is quite easy, needs only ten minutes.
ZYX-S 3-axis gyro system provides five different flight modes, which can satisfy players from beginners to advanced. ZYX-S 3-axis gyro system has many adjust options; pilots can adjust the parameter of swash plate and rudder servo, which make pilots feel the impressive of the flybarless helicopter.
ZYX high performance 3-axis gyro system uses MEMS gyro sensor which can be used in bad weather condition and pilots can control the flying status of helicopter precisely. Built-in pirouette flip optimization function, the speed of pirouette is really stable. When the helicopter pirouettes flip, the fuselage will spin at one point without shifting
Ecco in sintesi le nuove specifiche:
The ZYX-S and ZYX 3.0¡¯s new function:
1£ºThe ZYX-S add DSM2 and DSMJ satellite receiver support function.
2£ºThe ZYX-S add Futaba S-Bus receiver support function.
3£ºThe ZYX-S add failsafe function when using DSM2 and DSMJ satellite receiver,
user can set the failsafe values for throttle and collective pitch.
4£ºThe ZYX-S add four aircraft configrations: ¡®+¡¯ quadrotor, ¡®X¡¯ quadrotor,
conventional airplane(enhance hover and 3D flight), delta airplane.
5£ºThe ZYX-S can use the USB adapter to connect to PC, the new PC software is
ZYX 3.0. It can be setup by the ZYX multifunctional gyro programmer.
6£ºThe ZYX 3.0 add parameter explanation function, put the mouse on the parameter,
the explanation will be shown.
ZYX-S New Specification:
1) Dimensions: 37.2mm*25.2mm*13mm
2) Weight: 9.8g (not including connecting wire and adaptor)
3) Operating voltage: DC 3.5V-9V
4) Operating current drain: 60mA
5) Operating temperature:-15C~65C
6) Maximal angular velocity: 800 degrees/sec
7) Tail servo compatibility: 1.52ms analog servo, 1.52ms digital servo, 760us digital servo, 960us digital servo
8) Swashplate servo compatibility: 1.52ms analog servo, 1.52ms digital servo
9) Radio compatibility: PPM, PCM, 2.4G
10) Supporting firmware upgrade
11) Supporting Multi-Blade Rotor Head
