Originalmente inviato da TheJumper EVX-2 Profile DescriptionProfile
#1 (Sport Mode): 100% Forward, 100% Brakes, 100% ReverseProfile
#2 (Race Mode): 100% Forward, 100% Brakes, No ReverseProfile
#3 (Training Mode): 50% Forward, 100% Brakes, 50% Reverse
Selecting Sport Mode (Profile #1)
1. Connect two fully charged battery packs to the EVX-2 and turn on your transmitter.
2. With the EVX-2 off, press and hold the EZ-Set button until the light turns solid green, then solid red and then begins blinking red (indicating the Profile numbers).
3. When the light blinks red once, release the EZ-Set button.
4. The light will then turn green and the model is ready to drive.
Selecting Race Mode (Profile #2)
3. When the light blinks red twice, release the EZ-Set button.
Selecting Training Mode (Profile #3)
3. When the light blinks red three times, release the EZ-Set button.
Note: If you missed the mode you wanted, keep the EZ-Set button pressed down and the blink cycle will repeat until a Mode is selected. |
ah ecco, quindi con tutta probabilità entravo nella modalità Race... 1 Race 2 Sport 3 Training
certo sarebbe stato più comodo 1 interuttore fisico :\
per le lipo qualcuno sa consigliarmi di meglio?
HobbyKing R/C Hobby Store : ZIPPY Flightmax 5200mAh 2S2P 30C hardcase pack (DE Warehouse)
1. Connettori 4mm Bullet-Connector
2. Costo uguale o inferiore
passate pure il vostro ref link se vi trovate bene
