Vecchio 30 marzo 12, 16:10   #5 (permalink)  Top
micheFBRIpeak
L'avatar di micheFBRIpeak
Data registr.: 22-10-2009
Residenza: Lucca
Immagini: 9
Originalmente inviato da Robby Naish Visualizza messaggio
Ciao,
ho appena trovato questi nuovi modelli sulla warehouse tedesca di HK
Turnigy Trailblazer 1/8 4WD Brushless Monster Truck
The Turnigy Trailblazer is a high powered 1/8 4WD monster truck thats ready to crush the competition! With its powerful 14.8V 80A brushless system pre-installed, this truck has plenty of power to take on just about anything.
Large oil filled shocks, aluminum alloy drive shafts, 3mm 6061 T6 aluminum chassis, and sealed ball bearings all the way around shows that this truck means business!
It comes fully pre-assembled, and just requires your own 2CH radio system and batteries to get this truck running.
Features:
- 4 Wheel Drive System
- Almost Ready to Run (just install your own radio system)
- High Performance 2230 540KV Brushless Motor
- 80A EZRUN Brushless ESC
- 3mm 6061 T6 Aluminum Chassis
- Waterproof and Dustproof Sealed Gearbox
- Quality Differential with Four Bevel Gears
- Sealed Ball Bearings for Entire Model
- Aluminum Alloy Drive Shafts
- High Torque Metal Gear Servo Pre-installed
Specs:
Length: 504mm
Width: 385mm
Height: 188mm
Wheelbase: 335mm
Tire Size: 145x70mm
Ground Clearance: 46mm
Motor: 2230 540KV Brushless Inrunner (FB3650)
ESC: EZRUN-80A (EZRUN)
Servo: Std High Torque MG (9KG)
Required:
2ch Radio System (versione con radio circa 20 euro in piu)
14.8V (2 x 7.4V in series) 3000~3300mAh Lipo
Però.....
un monster 1/8 con esc XERUN completo a meno di 200€....
'zzo, per il cazzeggio non credo che ci sia niente di meglio che spendere poco e divertirsi tanto
micheFBRIpeak non è collegato   Rispondi citando
