Vecchio 30 marzo 12, 15:41   #2 (permalink)  Top
Robby Naish
L'avatar di Robby Naish
Data registr.: 16-10-2002
Turnigy Trailblazer XT 1/5 4WD Brushless Race Truck
The Turnigy Trailblazer XT is a high powered 1/5 4WD racing truck thats ready to dominate the track! With its powerful 14.8V 80A brushless system pre-installed, this truck has plenty of power to take home the win.
Large oil filled shocks, aluminum alloy drive shafts, 3mm 6061 T6 aluminum chassis, front/rear anti-sway bars, and sealed ball bearings all the way around shows that this truck means business!
It comes fully pre-assembled, and almost ready to run. Just add your own 2.4gHz radio system, 14.8V batteries (2 x 7.4V) and this truck is ready to race!
Features:
- 4 Wheel Drive System
- 3 Diff Transmission
- Ready to Run (just add your own batteries)
- High Performance 1500KV Brushless Motor
- 80A EZRUN Brushless ESC
- 3mm 6061 T6 Aluminum Chassis
- Waterproof and Dustproof Sealed Gearbox
- Quality Differential with Four Bevel Gears
- Sealed Precision Ball Bearings for Entire Model
- Aluminum Alloy Drive Shafts
- High Torque Metal Gear Servo Pre-installed
Specs:
Length: 670mm
Width: 430mm
Height: 230mm
Wheelbase: 480mm
Tire Size: 150x70mm
Ground Clearance: 70mm
Motor: 1500KV Brushless Inrunner
ESC: EZRUN-80A
Required:
2ch Radio System (versione con radio circa 20 euro in piu)
14.8V (2 x 7.4V in series) 3000~3300mAh Lipo
Robby Naish non รจ collegato   Rispondi citando
