Hei long, guarda che le due radio a parte la marca sono uguali, entrambe a 2.4, da giantood ce scritto che il modulo interno in 35mhz non è piu presente
Giantcod Guarantee Please note: This outfit no longer contains ANY 35mhz RF power stage and has been reduced to operate soley with the 2.4ghx module supplied. The picture will be updated asap.
The supplied the unit is ready to use with an exisiting 2.4ghz RF module operating with GFSK protocol. The module is pluggable and a Frsky or Corona JR styled RF module may be substituted. Applicable receivers would be required for either Corona or Frsky modules.
Transmitter Specification
Product Name: Transmitter
Frequency Band: 2.4GHz
Modulation: GFSK
Supported Model Type: airplanegliderhelicopter
Transmission Mode: PPM
Channels Qtty: 9 channels
Resolution: 10 bit
Model Memories Qtty: 8 models
Indicator Type: LCD
Transmitter Set: transmitter8 channels receiver
Battery
Battery Type: 8 cells AA 12 V (option)
Dimension and Weight
Dimension: 220mm x 185mm x 110mm
Weight: 680 gr
Receiver Specification
Receiver Model: AV-R8B
Channels Qtty: 8 channels
Modulation: GFSK
Resolution: 10 bit
Operating Voltage: 4.5V...6.5V
Weight: 18 gr
Dimension: 52mm x 35mm x 15mm *27/01/12 Please note these units do not come with internal antenna which is shown in the picture |
