Originalmente inviato da jhoexp Sicuramente lo sviluppo del software è parte impegnativa, ma da quale fonte hai saputo che è lo stesso?
Qui altra risposta di Rolf di Reisenauer, in merito all'affidabilità dei Sunrise e alla provenienza degli altri esc hk/himodel: For the realibility between Sunrise and YGE - our answer is yes, we sold
a lot of them the last month, and we get only positive feedback from our
clients.
About the nominal max ampere´s - YES THEY ARE REAL by the Sunrise. Here
in germany we have some People who fly Hotliners all time in overload.
some of them bought Sunrise ESC from us and they are more than satisfied
of the results from the ESC. One of them has a Sunrise ICE 100 A , he
pushes for short 149 Amp on the ESC without problems !! We test them to
the limit whats they build for and all time also to no problem.
about other distributors are marketing this ESC with other names - I am
honest and tell you the truth:
YES the turnigy dlux series and the Himodel ICE series are out of the
same manufacture ---- BUT not similar to the Sunrise ICE , Sunrise is
the manufacturer and sells also to as OEM to Turnigy as I know and what
I know to Himodel.
But not with the same hardware on it, there are little and big
differences, like the BEC on the Sunrise are bigger, the two Capacitors
are bigger and better, and other parts are also too in better quality. (
see the pic in the Attachment - the ESC with the green and red markers
are the himodel ).
When we thought about to take the Sunrise ESC to our
programm we tested also too a Himodel - result was a bad quality because
he can not handle high rpm. was a very bad result.
Thats the point we said we take the Sunrise because this ESC has a very
good Quality and a good price.
Its like I said before we look at Quality and want happy customers - and
when you know our folding prop spinners , you know what we mean with
quality :-) |
visto che li vende ad almeno il doppio del prezzo penso sia normale che affermi che sono due prodotti con qualche caratteristica diversa.
d'altronde è quantomeno normale anche che un prodotto abbia un'evoluzione e quindi una certa varietà nei componenti mi sembra plausibile anche se prendiamo lo stesso regolatore (stessa marca) a distanza di un anno o due.
ad esempio sempre per restare in argomenti esc cinesi io ho vari black mantis da 85amp, tra quelli più vecchi e quelli più nuovi ci sono molte differenze, addirittura uno (il più vecchio) è totalmente differente e tutto su un layer mentre gli altri sono a più strati.
Quindi è plausibile che i diversi brand possano avere delle "Release" diverse di uno stesso prodotto base, quello che è interessante capire è chi dice le bugie e chi no ( ovvero chi ti fa pagare il giusto)
