Servo waterproof per revino
Da Hitec. Che ne pensate?
The HS-5086WP is the smallest in Hitec's class of waterproof servos. With heavy-duty metal gears and a ball bearing supported output shaft, the HS-5086WP is among the most durable and reliable micro servo for wet conditions. Possessing the same size as our popular HS-85MG and the industry's first IP67*rating, this spunky mini will keep your RC vehicle, boat, aircraft or robot watertight, no matter what the weather or surroundings.
Expect More. Expect Hitec!
Features:
Metal Gear with MP First Gear
Top Ball Bearings
3-Pole Cored Ferrite Motor
Industrys First IP67-Rated Waterproof Case*
Programmable Circuit
Specifications
Motor Type:
3 Pole Metal Brush Ferrite Magnet
Bearing Type:
Top Ball Bearing
Speed (4.8V/6.0V):
0.18 / 0.15
Torque oz./in. (4.8V/6.0V):
42 / 50 oz-in
Torque kg./cm. (4.8V/6.0V):
3.0 / 3.6 kg-cm
Size in Inches:
1.22 x 0.60 x 1.22 in
Size in Millimeters:
31.0 x 15.2 x 31.0 mm
Weight ounces:
1.0 oz
Weight grams:
28.5 g
Yoko YZ-2 // Tekno EB410 // Losi Mini8 // Traxxas mini e-revo // Team Magic E5
