Eccole!
Scorpion HK-4025-1100KV (5mm Shaft) - Scorpion Power System
Specifications
Stator Diameter 40 mm (1.56 in)
Stator Thickness 25 mm (0.98 in)
No. of Stator Arms 12
Magnet Poles 8
Motor Wind 6 Turn Delta
Motor Wire 27 - Strand 0.29mm
Motor Kv 1100KV RPM / Volt
No-Load Current (IO) 2.40 Amps @ 10v
Motor Resistance (RM) 0.008 Ohms
Max Continuous Current 100 Amps
Max Continuous Power 2200 Watts
Weight 326 Grams (11.50 oz)
Outside Diameter 48.9 mm (1.9 in)
Shaft Diameter 4.98 mm (0.19 in)
Body Length 51.5 mm (2.01 in)
Overall Shaft Length 83.7 mm (3.30 in)
Max Lipo Cell 6s
Peak Current 130 Amps (5 seconds)
Peak Continuous Power 2750 Watts (5 seconds)
Motor Timing 5deg
Drive Frequency 8kHz
