Originalmente inviato da MONSTERUN |
ESC SPENTA,ACCENDI IL TELECOMANDO,PREMI E TIENI PREMUTO IL PULSANTE SET (QUELLO NELL'ESC),ACCENDI L'ESC,INIZIA A LAMPEGGIARE IL LED ROSSO E A FARE DEI BIP.
DOPO QUALCHE SECONDO LAMPEGGIA IL LED VERDE (1 VOLTA E FARA 1 BIP),A QUEL PUNTO SE RILASCI IL PULSANTE SET SEI ENTRATO NEL PRIMO MENU (RUNNING MODE),SE NON RILASCI IL PULSANTE SET (TI FARA 2 LAMPEGGI VERDI E 2 BIP E ENTRERA NEL SECONDO MENU,POI DOPO UN PO 3 LAMPEGGI E BIP ENTRERA NEL TERZO MENU,E COSI VIA FINO AL 5 MENU CON 5 LAMPEGGI VERDI E 5 BIP).PER CAMBIARE I PROGRAMMI BASTA PREMERE IL PULSANTE SET QUANDO SEI ALL'INTERNO DI UN MENU',(SE NON PREMI NIENTE I LAMPEGGI CORRISPONDONO AL NUMERO DEL SETTAGGIO CHE HAI)TI FARA DEI BIP E DEI LAMPEGGI ROSSI,IL NUMERO CORRISPONDE ALL'IMPOSTAZIONE CHE HAI DATO.PER MEMORIZZARE LE IMPOSTAZIONI DEVI SPEGNERE L'ESC. QUANDO TI FA UN BIP PIU' LUNGO CORRISPONDE AL NUMERO 5,QUINDI ESEMPIO BEEEEEP BEP BEP E NUMERO 7.PER RESETTARE TUTTO COME DA FABBRICA SE HAI PROBLEMI TIENI SCHIACCIATO IL TASTO SET PER PIU DI 3 SECONDI.TRA L'ALTRO CON LA PROGRAM CARD HAI MENO SETTAGGI CHE PUOI FARE SE CONTROLLI....CIAOOOOOOOOOO.....
