Vecchio 05 febbraio 12, 12:54   #10 (permalink)  Top
rugrug
L'avatar di rugrug
Data registr.: 08-03-2010
Originalmente inviato da mimmo7.2 Visualizza messaggio
ciao a tutti , per quanto riguarda la Xperience 8Ch 2.4GHz l'ho trovata su elishop a 129 euro usata ,invece la turnigy a 99 euro sempre in italia.
considerando le cifre, la Xperience 8Ch quardando la foto mi sembra qualitativamente a livello di materiali molto piu valida , non riesco a trovare informazioni invece sul software , mi icuriosisce il grande display retroilluminato. ma chi e' il produttore di questa trasmittente ???,
vi elenco le caratteristiche :
Main features:
1. digital trim
2. center point adjustment
3. 9 model memory
4. end point adjustment
5. servo revering
6. 6 character model name
7. dual rates
8. throttle cut ,hold
Function:
1. Digital Synthesis .There is no need to replace crystal; Automatic frequency selection to avoid interference with other communications.
2. Automaticly scanning receivers, High sensitivity and high-performance anti-jamming combination.
3. PCM 1024, high accuracy and large range , jumping to the total elimination of drift and rudder problems.
4. Large-screen liquid crystal display with backlight. Through the user interface settings menu, you can adjust all parameters, Programming give the possibility to control a variety of aircraft types.
5. And the proportion of action to respond to manipulation of any adjustable curve. Can switch in flight, will also be able to meet the needs of learners with special needs.
6. User programmable mixed-control mode To meet the exigence of variety types of helicopters. In case of airplanes possibility of controlling V-shaped tail, Delta-wing, as well as other special needs to control the model.
7. 9 memory storage
8. Fail safe setting
9. Throttle cut
CONTENTS:
Transmitter:XPT810 PCM1024,2.4GHz
Modulation mode: DSSS Operating system: 2- stick, 8- channel system
Power consumption: 300mA
RECEIVER: XPT8RX - 8 channels receiver of DSSS system receiving on 2.4GHz band
questo e' invece il link :
Ely Shop
vi richiedo nuovamente un consiglio
grazie a tutti
come ti hanno detto altri, mi sembra tu sia nella situazione in cui chiedi consiglio ma hai già deciso, ovvero non sapendo se fai un acquisto valido, stai cercando qualcuno che lo avalli, in modo da sentirti legittimato
sai qual'è il vero, reale e concreto "problema"?
è che chi compra una radio da poco, ben presto la cambia
e quando la vuol cambiare, una radio non di "marca" si vende molto male, quindi fai una spesa doppia
senza contare l'affidabilità del sistema, 'ché già con le Spektrum siamo al minimo funzionante
per farti capire la differenza:
una Spektrum dx6i usata si vende in un tempo compreso tra 30 minuti e tre giorni, a seconda dei canali che usi
