BaroneRosso.it - Forum Modellismo - Visualizza messaggio singolo - Xperience 8Ch 2.4GHz Radio System
Vecchio 05 febbraio 12, 09:41   #7 (permalink)  Top
atomas72
Moderatore
L'avatar di atomas72
Data registr.: 16-04-2007
Originalmente inviato da mimmo7.2 Visualizza messaggio
ciao a tutti , per quanto riguarda la Xperience 8Ch 2.4GHz l'ho trovata su elishop a 129 euro usata ,invece la turnigy a 99 euro sempre in italia.
considerando le cifre, la Xperience 8Ch quardando la foto mi sembra qualitativamente a livello di materiali molto piu valida , non riesco a trovare informazioni invece sul software , mi icuriosisce il grande display retroilluminato. ma chi e' il produttore di questa trasmittente ???,
vi elenco le caratteristiche :
Main features:
1. digital trim
2. center point adjustment
3. 9 model memory
4. end point adjustment
5. servo revering
6. 6 character model name
7. dual rates
8. throttle cut ,hold
Function:
1. Digital Synthesis .There is no need to replace crystal; Automatic frequency selection to avoid interference with other communications.
2. Automaticly scanning receivers, High sensitivity and high-performance anti-jamming combination.
3. PCM 1024, high accuracy and large range , jumping to the total elimination of drift and rudder problems.
4. Large-screen liquid crystal display with backlight. Through the user interface settings menu, you can adjust all parameters, Programming give the possibility to control a variety of aircraft types.
5. And the proportion of action to respond to manipulation of any adjustable curve. Can switch in flight, will also be able to meet the needs of learners with special needs.
6. User programmable mixed-control mode To meet the exigence of variety types of helicopters. In case of airplanes possibility of controlling V-shaped tail, Delta-wing, as well as other special needs to control the model.
7. 9 memory storage
8. Fail safe setting
9. Throttle cut
CONTENTS:
Transmitter:XPT810 PCM1024,2.4GHz
Modulation mode: DSSS Operating system: 2- stick, 8- channel system
Power consumption: 300mA
RECEIVER: XPT8RX - 8 channels receiver of DSSS system receiving on 2.4GHz band
questo e' invece il link :
Ely Shop
vi richiedo nuovamente un consiglio
grazie a tutti
Ciao Mimmo,
ti hanno già risposto.
Sarebbe meglio tu comprassi una DX6, è più conosciuta e probabilmente più valida.
Sembra invece che tu abbia già scelto, se ti piace di più comprala.
Non è postando le caratteristiche di questa radio che possono cambiare le opinioni già espresse.
"C'è una forza motrice più forte del vapore, dell'elettricità e dell'energia atomica: la volontà."
Albert Einstein
atomas72 non è collegato   Rispondi citando
