Originalmente inviato da neo11 |
I do not own that particular radio but I am very much led to believe your issue is a very simple one... the THSTICK message and repeating alarm beep on the initial screen are warnings that you are not at low throttle position. Looking at the throttle stick in the video confirms this.
Try lowering your throttle stick tp its lowest position next time and I believe your radio will start normally.
Most radios made in the last few years will do this.
bene, direi che proviamo a fare / controllare questo
-stick gas a zero
-trim gas a zero
-che mode hai ?
-prova a tenere giù anche lo stick
CON LA MOLLA, PRIMA DI ACCENDERE LA RADIO (NON COLLEGARE L'ELICOTTERO PRIMA CHE ABBIAMO RISOLTO... PERICOLO !!! esegui e riferisci
