Discussione: Club Blade 400-450
Vecchio 03 gennaio 12, 23:54   #1404 (permalink)  Top
bandit
L'avatar di bandit
Data registr.: 18-12-2010
Originalmente inviato da david Visualizza messaggio
tutti! c'è una tabellina riassuntiva per caso?
nella bibbia del 400 USA
#16- FACTORY SETTINGS
Factory throttle curves are:
Norm: L = 0%, 2 = 25.0%, 3 = 50.0%, 4 = 75.0%, H = 100%
Stunt: L = 100%, 2 = 92.5%, 3 = 85.0%, 4 = 92.5%, H = 100%
Hold: 0.0%
Factory pitch curves are:
Norm: L = 35.0%, 2 = 42.5%, 3 = 50.0% (0 pitch) 4 = 75.0%, H = 100.0%
Stunt: L = 0.0%, 2 = 25.0%, 3 = 50.0%, 4 = 75.0%, H = 100.0%
Hold: same values as Norm pitch
Some of the setup list values are different from what is shown on Page 79 of the Spektrum manual. I will only list the items that are different from the manuals values:
Model Name: BLADE400
Reverse: AILE-R, RUDD-R (all others N)
swash type: CCPM 120*
Thro Cut: Position - INH
Timer: Down timer - 04:30
Now for the adjust list (Page 105).
D/R&EXPO: the "0" switch positions for AILE and ELEV are at 90% D/R. All EXPO's are at INH. Travel Adj: RUDD: <90% and >90% (note you have to move the rudder stick left & right to set the separate values).
Gyro: Rate 0: 66.5% Rate 1: 64.0%
Throttle and pitch curves as listed above
Swash Mix: AILE: -75%, ELEV: -75%, PITCH: +85%
Mix 1: INH
Mix 2: INH
La bibbia dei Bladoni V6, Blade 120SR - Guida Crius Aio Pro V1.3
ATOM 500 - Blade 400 FBL STRETCHED 6s - 120SR.
bandit non è collegato   Rispondi citando
