HO TROVATO LE ISTRUZIONI DEL MODELLO!!! LEGGILE QUI SOTTO O VAI AL SITO http://www.alfamodel.cz/ G) Completing the model
The controller, receiver and battery are attached to the tray using the self-adhesive Velcro strip as shown on Fig. B2. The receiver should be as far as possible from the battery, motor, controller and power cables. Lead the antenna to the surface of the fuselage. We do not recommend to lead the antenna inside the fuselage because of the shielding effect of the metal pigment in the paint.
Insert and glue the assembled and painted pilot into the canopy by an opening cut in the canopy bottom.
Attach the wing with bolts, insert the battery into the fuselage and check the position of the centre of gravity.
The prescribed CG position is marked by the lines moulded in the fairing 5 on the wing underside (Fig. C1). The model, supported in this place by fingers, should stay level or slightly nose down..
Il
Fairing è la carenatura che ricopre le ali sotto l' ala ci sono due linee in rilievo, ci metti le dita e lo bilanci lì spostando avanti o indietro la batteria.
http://www.alfamodel.cz/php/index.ph...21&_RQsiz=midi
