Discussione: Spektrum Dx8
Vecchio 10 dicembre 11, 09:22   #2601 (permalink)  Top
baracca1
L'avatar di baracca1
Data registr.: 01-08-2008
Residenza: TORINO
Talking Lo sapete ?
Beastx+ Rx 7 ch !
In pratica la rx viene a costare circa 35 euro !
Horizon Spektrum AR7200BX 7-channel DSM RX
Spektrum (SPMAR7200BX) AR7200BX 7-channel DSM™ receiver with integrated flybarless control system
Overview
Going flybarless is a great way to unleash the animal in any 3D helicopter. By eliminating the mechanical complexity and weight of a flybar, you get faster MEMS flybarless stabilisation system is the most powerful flybarless technology available today. Its unrivaled responsiveness and precision completely transforms any 3D flying experience.
Now BeastX technology can be added to most any 250- to .90-size helicopter, while saving space and reducing flying weight at the same time, with the Spektrum™ AR7200BX. This groundbreaking innovation combines a 7-channel DSMX™ receiver with the BeastX system into a single, compact unit that weighs a minimalist 18 grams. It also has an incredibly small footprint, so it’s easy to find mounting space on even the most crowded heli frames.
Perhaps best of all is how simple the AR7200BX is to set up. Because BeastX flybarless technology doesn’t require a special interface to make adjustments ,It can easily be tuned to a heli’s response at the field using just the AR7200BX unit and a DSM2/DSMX computer transmitter with heli programming.
Specification:
• Application: 250- to 800-size helis
• Channels: 7
• Receivers: 1 with support for additional remote receiver
• Modulation: DSM2/DSMX
• Band: 2.4GHz
• Dimensions: 36.0 x 29.0 x 13.0mm (1.30 x 1.10 x 0.51 in) (LxWxH)
• Weight: 0.63 oz (18.0g)
• Input Voltage: 3.5-8.5V
• Resolution: 2048
• Frame Rate: 11ms
• Dual Antenna Length: 110mm/40mm
• Range: Full
Features
• Data/Telemetry Compatible:Works with Spektrum Telemetry Transmitter systems and flight log information.
• Integrated 3-Axis MEMS GYRO Control System: 3-axis gyro and stabilization provides maximum precision, stability, and control for advanced
• 3D manoeuvres. Combined with Spektrum DSMX and DSM2 Technology.
• 2S Li-Po Capable: Variety of power sources available
• 7CH Receiver: Integrated Spektrum 7CH Receiver, capable of both park flyer and full range applications
• Built-in swashplate mixer: Mechanical, 90, 120, 140 degree
• Compact Footprint : Easy installation in 250 - 700 size electric and Nitro Helicopters
• Large Voltage Range Input: Operating voltage: 3.5 - 8.5V
• PC Programmable : Allows for updating firmware, and advanced settings via USB.
• Selectable Servo Centre Pulse Width: Tail Servo: 1.52ms, 0.96ms, 0.76ms
• Selectable Servo Pulse Rate: Tail: 65Hz, 270Hz, 330Hz Swashplate 65Hz, 120Hz, 200Hz
• User Friendly Setup and Programming: No PC required, allows for field adjustability.
baracca1 - MCX2 - PROTOS 700 MAX V2 - Logo550 VBar Carbon - DEVIL 380 - ESACOTTERO CRIUS AIO V2 - EACHINE E010 + H8 - SPEKTRUM DX8 - Ferrovia MARKLIN H0
baracca1 non è collegato   Rispondi citando
