Ne avete già parlato ?
Frequento a singhiozzo .... avete visto cosa c'è in arrivo per chi usa Spektrum ?
Chissà se il ns .. "Papy Egidio" ne sà qualcosa ?
Con circa 35 euro in più hai una 7ch oltre la compattezza dell'insieme...
Fffurbo sembra.. o no ?
Horizon Spektrum AR7200BX 7-channel DSM RX
Spektrum (SPMAR7200BX) AR7200BX 7-channel DSM receiver with integrated flybarless control system
Overview
Going flybarless is a great way to unleash the animal in any 3D helicopter. By eliminating the mechanical complexity and weight of a flybar, you get faster MEMS flybarless stabilisation system is the most powerful flybarless technology available today. Its unrivaled responsiveness and precision completely transforms any 3D flying experience.
Now BeastX technology can be added to most any 250- to .90-size helicopter, while saving space and reducing flying weight at the same time, with the Spektrum AR7200BX. This groundbreaking innovation combines a 7-channel DSMX receiver with the BeastX system into a single, compact unit that weighs a minimalist 18 grams. It also has an incredibly small footprint, so its easy to find mounting space on even the most crowded heli frames.
Perhaps best of all is how simple the AR7200BX is to set up. Because BeastX flybarless technology doesnt require a special interface to make adjustments ,It can easily be tuned to a helis response at the field using just the AR7200BX unit and a DSM2/DSMX computer transmitter with heli programming.
Specification:
Application: 250- to 800-size helis
Channels: 7
Receivers: 1 with support for additional remote receiver
Modulation: DSM2/DSMX
Band: 2.4GHz
Dimensions: 36.0 x 29.0 x 13.0mm (1.30 x 1.10 x 0.51 in) (LxWxH)
Weight: 0.63 oz (18.0g)
Input Voltage: 3.5-8.5V
Resolution: 2048
Frame Rate: 11ms
Dual Antenna Length: 110mm/40mm
Range: Full
Features
Data/Telemetry Compatible:Works with Spektrum Telemetry Transmitter systems and flight log information.
Integrated 3-Axis MEMS GYRO Control System: 3-axis gyro and stabilization provides maximum precision, stability, and control for advanced
3D manoeuvres. Combined with Spektrum DSMX and DSM2 Technology.
2S Li-Po Capable: Variety of power sources available
7CH Receiver: Integrated Spektrum 7CH Receiver, capable of both park flyer and full range applications
Built-in swashplate mixer: Mechanical, 90, 120, 140 degree
Compact Footprint : Easy installation in 250 - 700 size electric and Nitro Helicopters
Large Voltage Range Input: Operating voltage: 3.5 - 8.5V
PC Programmable : Allows for updating firmware, and advanced settings via USB.
Selectable Servo Centre Pulse Width: Tail Servo: 1.52ms, 0.96ms, 0.76ms
Selectable Servo Pulse Rate: Tail: 65Hz, 270Hz, 330Hz Swashplate 65Hz, 120Hz, 200Hz
User Friendly Setup and Programming: No PC required, allows for field adjustability.
baracca1 - MCX2 - PROTOS 700 MAX V2 - Logo550 VBar Carbon - DEVIL 380 - ESACOTTERO CRIUS AIO V2 - EACHINE E010 + H8 - SPEKTRUM DX8 - Ferrovia MARKLIN H0
